1 - 10 of 10 Posts
Hi,
I was wondering what it take to replace the shifter shaft on a 97 speed triple. ( the part where the shifter lever slides on coming out of the trans)
to me it looks like it could be replaced by removing the oil pan possibly but thought i would check on here first.
any help is appreciated.
mike
2004 Daytona 955i, 2018 Indian Roadmaster, 2014 Triumph Scrambler, 1980 CB650C in resto
Have you checked out the exploded views on the parts fiche at Bike Bandit? That could help you figure it out.
yes i did check those out and found someone on here saying if you pull the clutch basket they thought you could replace it that way.
I had to split the case when I did mine, But I ran my shifter like that for one season before I replaced mine. Just put som green lock tight on the remaining splines of the shaft and use a nut and bolt threw the shifter lever hole to tighten up lever. Worker out well.
never had any problems.
really are you sure that is how it has to be done?
Discussion Starter · #7 ·
First, are you sure you need to replace the shaft? If the problem is sloppiness in the shifter, that can be fixed by changing the bushing in the shifter lever.
that shaft is broken off about 1/2 the length as stock. Sorry the pictures must not show that real well.
sure if you will post up the pictures that would be great.
I was only able to find the quadrant the pice that hooks to the shaft. A C-clip holds it on with a retaining spring. You could try to get to it from the oil pan or clutch cover taking it off. I just think it will be very hard to align the quadrant gear to the shaft with the spring. Let me know how it work out for you, as I know I will brake a nother shaft on my track bike.
1 - 10 of 10 Posts
