1 - 2 of 2 Posts
Hi, I have a 2010/2011 Speed Triple SE and the brake lever is losing pressure over time. I need some experienced advice on next steps. I first blead everything and about 2 weeks later it was back to no pressure, I took it to a shop who rebuilt the master cylinder and again after a few weeks back to no pressure. Last night I blead only the master cylinder and I got pressure back. My thought is this means its for sure the master cylinder and the next logical step is to replace the full Master cylinder assembly but wanted to ask before I spend $300 and end up in the same place. Thanks
Seeing as rebuilt properly, bled and no leaks present, there may be trapped air regular bleeding is not pushing through. Try power bleeding before proceeding with replacement.
1 - 2 of 2 Posts
