With the electronic Ohlins suspension, I am wondering if the street harshness I had on my demo ride of the RS can be easily tuned out? Or, is it a more involved thing than a simple spring rate and dampner tweak?
TIA,
Sid
Speed Triple 1200 RS
TIA,
Sid
I have just about tuned out the harshness on my RS. NB Not Electronic.
I wound the spring preload of the forks right back, but only needed to make some minor adjustments to the damping.
I also increase the damping on the rear shock, and the bike is much better balanced.
I have been meaning to get out in the garage and make a note of the actual settings I arrived at. I'll post them when I get time.
Thanks! That would be appreciated.
Where I ended up with mine (RS)
Rear Shock - OEM 6 thread lines showing NOW 3 lines showing, Compression +2 clicks from minimum, Rebound 18 out from full in
Front Forks- OEM 4 turns in from full out NOW 1 turn in from full out, Compression 18 out from full in , Rebound 18 out from full in.
It is a very taught ride even with relaxing the springs, and "softening" the damping. Very much a sport bike feel. When the RR was announced, the suspension "made sense" on the RS, all things considered.
...it is what it is. Love the bike!
