Status
Not open for further replies.
1 - 1 of 1 Posts
Make Model: Triumph Tiger 900
Year: 1997-98
Engine: Liquid cooled four stroke, transverse three cylinder, DOHC, 4 valve per cylinder.
Capacity: 885
Bore x Stroke: 76 x 65 mm
Compression Ratio: 10.6:1
Induction: 3x 36mm Flat side CV
Ignition / Starting electric
Max Power: 85 hp 62 kW @ 8000 rpm
Max Torque: 82 Nm @ 6000 rpm
Transmission/Drive: 6 Speed / chain
Front Suspension: 43mm forks adjustable for compression and rebound damping
Rear Suspension: Monoshock adjustable preload
Front Brakes: 2x 276mm discs 2 piston calipers
Rear Brakes: Single 255mm disc 2 piston caliper
Front Tyre: 110/80-19
Rear Tyre: 140/80-17
Seat Height 850 mm / 33.1 in
Dry Weight: 209 kg
Fuel Capacity: 24 Litres
Consumption Average: 16.2 km/lit
Braking 60 - 0 / 100 - 0 14.0 m / 42.95m
Standing ¼ Mile: 12.3 sec / 171.8 km/h
Top Speed: 201.2 km/h
1 - 1 of 1 Posts
Status
