1 - 8 of 8 Posts
Hi!
What tool do you guys use to remove the spark plugs?
Thank you
2004 Thruxton, gel seat, TOR
I use an 18 mm deep socket on mine with the AI having been removed. I don't know if that will work with the AI still on the bike.
Shorty
Trying hard not to sound sarcastic here... I'd use a 'spark plug spanner' (or 'spark plug wrench' to those on the 'wrong' side of the water)
This is a purpouse made socket, with a rubber insert which supports the ceramic insulator and holds the plug in the socket while you feed it down between the fins.
Pete.
Not to sound sarcastic, but... with the AI, a very slim socket is needed!
Cannot seem tto find one that wouldn't force me to lift the back of the gas tank.
jb
[ This message was edited by: cameracsc on 2005-08-02 15:12 ]
I use a spark plug removal tool.. I bought it years and years ago from a Yamaha dealer, it's stamped with Yamaha on it. Its basically two pieces the part that goes over the plug, and a rod to put in to it to turn it, works great.
Cameracsc,
After you break the plug loose with a ratchet and socket just remove the rachet and turn the socket by hand to get the plug out. Of course this works better if the engine is cool.
I use a Sears Craftsman 18mm spark plug socket with the rubber insert.
Bill
1 - 8 of 8 Posts
