1 - 3 of 3 Posts
smiths;
can anyone recommend a good and honest restorer of speedo's in the UK? mine needs some TLC and work.
brakes;
am not too impressed with all the connections between the master front brake cylinder and the calipers - prone to leaks and difficult to work with. anyone out there got any good setups and/or suggestions? would like to keep the master cylinder to save $'s but open to any suggestions - the main problem appears to be the brake light switch and incorporating it into the build. a custom switch on the brake lever would be my preferred design. come on experts..
Tks again.
Hi Eddie,
For speedo try A A Gagg & Son in Nottingham Phone 01159786288. Re brake light switch incorporated in the RH h/bar housing (they are crap!) ring TMS on 01159503447 and they'll supply you with an inline hydraulic switch and the pipework to suit.
I have used both and can recommend highly.
Best of luck,
Richard
1 - 3 of 3 Posts
