1 - 14 of 14 Posts
I seem to recall a while back that someone else posted a similar topic? I installed a set of TORS a while back and had the Triumph map uploaded. The pipes didn't slip right on. I had to enlongate the hole in the mounting tab on the right. Once I had that done, everything seems pretty tight and even, but when I get home, I smell like I have been swimming in gas. My friend says that when he follows me that it smells really rich. I know the TORS map is rich, but man...Anyone else had a similar experience?
Huff
Huff
So you have a smelly rear end,the doctor should have something for that. :-D :hammer:
Take a shower and wash that a$$.
Huff
:-D
A K&N or BMC intake filter may help lean things out.
My bike seems to start easier since the K&N, It use to be really rich smelling on starts.
+1 :-D
Don't forget that when you switch to TOR's from stock that you drop some weight specifically the catalyzers that really clean up the exhaust on its way out. I was unsure of how effective the CATs were until I made the switch myself. Oh well, I think it is a good smell :cool:
Are you yalkin about the bmc air filter? If ya are let me know what ya come up with. With all the fitment issues of the K&N i think i will go that route.
No problem on the burn, it was a good one. :-D
Discussion Starter · #14 ·
Itchy,
Thats why I was looking to go the BCM route, but the only one I've found so far was $85, that was directly from BCM. If I recall, the guy on ebay had them for like $60. Ill keep lookin
:-D
1 - 14 of 14 Posts
