I noticed that after a month or 2 my engine turns over slower. I let it go until I got an engine fault light. It was the fuel pump relay. I cleared the code after recharging my battery.
Here is what I see. Battery charges, wait a week with it disconnected and it is at 3.13 v. Install it and same 3.13 volts.
Start bike and at idle is jumps from 3.20 to 3.30 with spikes to 3.4.
Rev it to 2500 RPM and the voltage stabilizes at 14.0 V.
So every time I start the bike, I am using battery power and at a stop, it really isn't charging the battery. I get a slight charge above 2500 RPM but since I drive 4.5 miles to work, that is not enough to replace the energy I used to start the bike.
Should I do the modification to increase efficiency or is there a problem with my charging circuit?
