1 - 3 of 3 Posts
Got the bike running better now, thanks to everyone’s help.. so been out on it tonight and have another small issue.
When it’s hot (after about 2 miles), it can miss on opening the throttle (just of closed position). Does not do it when under load.. you let off and wind back on again, it’s okay... It does it when you’re going downhill on over-run, then you slightly open up... just one miss then off... Or if you’re at tick over.., just one miss and off.... or over-run on the flat... just a miss then off....?
Any thoughts?... got a Boyer fitter... could it be the bits getting warm... pulls like a train otherwise and Amal MK2’s... could it be air screw (1.5 turns out).. or some other jetting issue?... cheers :smile2:
1 - 3 of 3 Posts
