I have noticed nearly imperceptible movement all the way up to what seemed like nearly 1/4" of slop in the BASKET, all working normally.
Where you will get serious troubles are ANY amount of "play" or "slop" in the HUB section. The slightest looseness will cause the key to shear, and the slightest wobble of the shaft will cause everything in the primary case to wear out quickly.
