1 - 11 of 11 Posts
Can anybody recommend some frame or axle sliders for a TBS that would protect the mufflers in a crash? I went down on the left side a few weeks ago, and even though the bike was banged up pretty good, nothing too expensive was damaged and I should be back on the road after only spending about $600. I shudder to think what it would have cost me had I gone down on the right side onto the pipes, so I'm hoping theres something out there that would keep them off the pavement.
lol...okay seriously...if you find something, let me know! This too has been a concern of mine although I have not yet been the victim of gravity, I do know the possibility exists. In my mind I just can not imagine anything that would work that wouldn't stick out too far.
I doubt there's anything 'off the shelf' for a TBS, but how about making some kind of sacrificial heat shield type type of thing?
(or start saving now for the Thunderbike 3 into 1 you want to put on :D )
What exactly do they protect?
They are on the upper engine mount so the exhaust and the shifter/brake lever and foot pegs will slide on the bottom. They don't stick out far enough to protect the handlebars and mirrors, I don't think. Will they even save the headlight mounting ears?
They do look good, though :cool:
Discussion Starter · #10 ·
I was wondering about that. That's all they would protect, the engine cases? I can tell you from experience the horn does a pretty good job of that already, at least on the left side.
I ground my Skyking down a bit on the right side when I fell over. I still bent the bars a bit, and the Napolean mirror got ground a bit (sticks out a bit more than the handle bar). It did take some of the brunt though.
On the left I got a longer bolt and made a spacer so that it stuck out a ~1-1.5" further to protect a Stebel airhorn (mounted on the left side of the radiator shield). But the trailer hitch on the truck it slid under took out the horn & radiator before it got to the slider.
Stuff gets broken when things fall over and/or slide. Especially when you are trying to keep a lean profile. You could look into how to mount a slider on the swing arm, but that implies other issues: swing arm damage or maybe less ground clearance; handling as there would be more unsprung weight (hard to make that argument if you have the portly stock steel rims).
There are a couple of the crash bar types out there, but still limited on the rear protection. Look at the dressers (especially HD or MG California type) for rear crash bars.
1 - 11 of 11 Posts
