1 - 10 of 10 Posts
Sweat,I moved my igniter to behind the sidecover,no problem. I mounted it to the little hooks that held the 2 flashers,then rubber taped the flashers to the igniter.There`s plenty of room for the unplugged wire harness to be relocated without cutting any wire.
rodburner, pics of the relocation efforts please?
Wow,that post was a year ago. I`ve pretty much relocated all the underseat/affixed to airbox wiring into this 8x6x4" battery box. I didn`t cut any wires,just removed some of the bundle sheathing and re-routed stuff.
The 2 flashers and some connectors are in the box,beside the battery,the thicker wire bundles are down in the box,in front of the battery and the fuse box,ignition module and that thingy with the heavy power cables going to it,all just lay on top the battery,zip tied to a thin ABS sheet.
1 - 10 of 10 Posts
