H
HighMtnLakes
·Guest
I'm a newbie to this forum, so apologies in advance if this is an old topic.
I bought this turn-signal canceller http://www.customdynamics.com/kisan_signal_minder.htm
from http://www.newbonneville.com/html/signalminder.html.
New Bonneville has been a great after-market dealer in case you haven't stumbled across them.
I hooked up the running lights and brake suspend option and I'm getting weird behavior with the turn signals. Kisan tech support says I probably need to replace the instrument panel turn signal indicator bulb with an LED, such as from http://www.superbrightleds.com/, but they don't say which LED to use.
Before I take apart the instrument panel-- anyone else have this same problem and have a fix for it, like whether I need to replace the bulb, and which LED to use?
Thanks!
Enjoying a new red/black T100 in Louisville CO...
Thanks!
