1 - 10 of 10 Posts
Hey all!
Can anyone tell me where the turn signal relay is located on my ‘17 street twin? I’ve looked all over , maybe I’m just blind....
Hi, Its a built in function of either the ECU or the instrument cluster and not a separate device, If you need to change the blinking rate due to swapping out the indicators you can do this
Shows how
No need for resistors after mounting LEDs as the new WC bikes are set up for them from the factory and it the same set up with all the WC models as I have just done the same a just over a week or so and knew about the imfo button trick.
Ashley
^^^ Thats me. :grin2:
Did your hazards work after switching them in the ECU? I placed three LEDs on my Street Cup..but the front right blinker wont work unless it is a bulb. I switched the ECU to make them slow down..but the hazards dont work.
Yes, they still work. Sorry for the late reply.
My hazards dont work since switching to an LED headlight, but the blinkers still work so Im not sure whats going on.
as i noted in another post it says all blinkers MAY NOT be compatible with the Triumph adjustments + a load equalizier may be needed!!
1 - 10 of 10 Posts
