Hi all. Been having a problem with my winkers/turn signals. The local dealer install a signal minder about 2 years ago. No problems until I switched my bars. I probably change out the bars 2-3 times a year. Now my signal minder doesn't seem to be working properly. I switch to the right turn sig.and all is fine. Then activate the left turn sig. and must hold the switch to the left for the sig.to work . As soon as I take my thumb off the switch, the winker shuts off. Is the switch is bad?
Has anyone had this issue?
