I installed my GPS today and managed to fish a wire through without removing the cover but I really would have liked to take off the cover.
It looked like it should just snap out but I gave it a lot of effort and it didn't.
So I stopped before I broke it.
Anyway...........anybody know how to remove it?
TIA
:confused: I lifted the tank to take a peek on the backside, it looks like a bit of effort would be needed to bend the piece enough to clear the frame, haven't tried it myself though :eek:
You really should consider some type of bulkhead fitting, or at least a rubber grommet where the wire passes through. A fitting to plug accesories into would be the smart move. :)
Neanderthal
Neanderthal
The wire for the gps comes out the notch with all the other cables. It's just a skinny speaker wire that ends in an sae connector. It's on a 2 amp fuse.
I also have a heavier wire that I can feed out in front of the seat, just below the tank, that ends in another sae connector.
That's on a 10 amp for my heated jacket or my air compressor or trickle charging the battery.
