1 - 3 of 3 Posts
My friend has a single seat/rack setup on her SE.
Unfortunately the 'hook' on the underneath of the pan that hooks in near the petrol tank when you reattach the seat is broken.
Is there any way to replace/repair this so that the seat sits more securely?
Sent from my SM-G950F using Tapatalk
If the broken tab is still partly attached it may be possible to get it plasti-welded or even try some of that super dooper glue that you see advertised. If it’s broken away completely you can get a piece of metal bent to shape and rivet or bolt it to the pan. I’ve seen both done.
CanberraR3 thanks for the advice ;)
I will see what I can come up with, the part is broken off.
1 - 3 of 3 Posts
