1 - 3 of 3 Posts
Hi Lads,
I just ordered the OEM Tach for my Scrambler.Can anyone tell me where it plugs in? I'm sure it comes with installation instructions,but I was just wondering what to expect once it shows up.
The kit does indeed come with good instructions. If it's anything like the bonnie there will be a plug in in the wiring loom, which in the case of the bonneville is in the headlamp.
Yes, it plugs into the harness in the headlamp. There are two two-wire connectors. One is for the tach itself and the other is for the lights.
I don't have a tach, btw, but I tap into the harness occasionally with a handheld digital tach to check the idle or maybe adjust the mixture.
1 - 3 of 3 Posts
