1 - 15 of 15 Posts
Administrator
What’s a scrambler? In decades past, a scrambler was a street motorcycle stripped down and optimized for off-road use by way of swapping-in high-pipes, wider handlebars, semi-knobby tires, and differently styled fenders, seat and tank. Sometimes, it was an unmodified street model given a scrambler or street scrambler designation. In essence, it’s a cool name meant to convey agile sportability regardless of the bike’s dirt or street intentions.
Recently, Scrambler’s been the name affixed to a modern throwback Triumph that’s been playing in its own sandbox for years. Ducati finally took notice of Triumph’s cornering of the scrambler market and, having scrambler models in its own historical record, decided to expand the segment with not just one scrambler model, but with four: Icon, Urban Enduro, Classic and Full Throttle.
We’ve solo-tested the Triumph Scrambler, most recently in 2012 by EiC, Kevin Duke, while Troy Siahaan conducted a first-ride review of Ducati’s scrambler models as recently as last December, at the press launch in Palms Springs, California.
Bringing together these scramblers from competing OEMs has been our goal, which we’ve now realized in the Ducati Scrambler Icon and Triumph Scrambler. Both bikes adhere to, and extoll the values of, their predecessors, but which Scrambler is the better one to scramble upon? That depends on which definition of scrambler you prefer.
Authentically nostalgic all the way down to its fork gaiters. Producing only 50.7 horsepower, maybe the Triumph is a little too nostalgic. “The Trumpet’s parallel-Twin is super usable, with smooth power available at every point of its powerband. It’s flawless if you’re not in a hurry,” says co-scrambler Kevin Duke.
Although Triumph never had a model specifically named Scrambler until this modern iteration, it is the scrambler here Steve McQueen would best recognize. Seemingly beamed directly from 1967, the Triumph Scrambler epitomizes the high-pipe, wire-wheeled on/off-roaders of yore.
The Scrambler Icon, on the other hand, is a modern interpretation of scramblers from Ducati’s past, but if you compare the modern with the original, the new bike bleeds its heritage from most angles, with mag wheels, upswept exhaust and V-Twin engine being the most obvious differences. Also, like the originals, Ducati’s modern Scramblers aren’t really meant to be taken off-road.
Ducati Scrambler Retrospective
“The Triumph is built much more appropriately for true off-road travel,” says Duke. “It plays the rugged tank to the Ducati’s livelier option, and the Trumpet has several advantages over its sportier rival, including greater comfort, much better off-road-ability, and preferable around-town behavior.”
In true scrambler fashion, the Icon – as well as Ducati’s other scrambler models – are (to some degree) 796 Monsters in scrambler drag. The Icon’s modernity shows, as it outperforms the Triumph everywhere except for in the dirt.
The around-town behavior of the Icon’s is less refined, spoiled somewhat by abrupt responses to minor throttle inputs, creating herky-jerky riding that’s especially apparent in stop-and-go urban traffic. This condition is exacerbated on bumpy roads and reveals itself plainly when trying to maintain a steady speed on a bumpy freeway. The 803cc V-Twin is also surprisingly cold-blooded, needing to be warmed before cleanly accepting throttle. And, on a couple of occasions while fully warmed, it coughed and flamed out when leaving a stop.
“I’m extremely pleased that an air-cooled Ducati engine lives on in the Scrambler,” says Duke, “however, it’s fueling behavior is annoyingly flawed. Thankfully, Ducati is aware of the issue and will be offering a revised fuel map for the Scrambler in the next few weeks.”
Ducati’s V-Twin is 62cc smaller than Triumph’s parallel-Twin yet it produces 19 more horsepower and nearly two pound-feet more torque. To say the Triumph engine is mildly tuned is an understatement.
Still, when it comes to smiles per mile, the Ducati embarrassingly shames the under-powered Triumph. The poor state of the Duc’s around-town fueling issues are all but forgotten when a smooth, snaky canyon road presents itself, leaving the Triumph looking cool in its rearview mirrors.
It’s also in a tight set of switchbacks where you realize just how throwback the Triumph’s frame really is. Just like a ’60s-era bike with a steel downtube frame, you’re gonna feel it flexing.
“Hopping off the Duc and onto the Triumph makes the English bike feel long and lardy,” says Duke. “The Triumph’s steering is much heavier than the Duc’s, but it reacts neutrally and without surprises.”
It took mere minutes of off-road riding before the connecting spring was ripped from the bottom of the Icon’s exhaust. Paved or graded dirt roads only need apply. Minimal trellis frame and stressed-member engine keep the Icon composed when ridden aggressively on the street.
For scrambling over anything other than pavement, the Triumph is the bike of choice. The chassis is neutral and forgiving, it’s 19-inch front wheel confidence inspiring, and its lopey, heavy-flywheel-engine is easy to manipulate. Comparatively, the revvy nature of the Ducati Twin tires your clutch hand with all the lever manipulation needed to traverse a rocky off-road area.
New Triumph Bonneville Spied!
The Triumph is also the more comfortable of the two scramblers. Its handlebars come further back greeting the rider, and aren’t quite as wide as the Duc’s. The Triumph has a more generous steering sweep, and most importantly, the Triumph’s seat is richly padded and its flatness allows for a rider changing his seating position, compared to the Icon’s scalloped seat that locks a rider into one position.
The Triumph’s high-pipes do more than just look cool when navigating around and over off-road obstacles. The Trumpet also wears a bash plate below its frame rails, and carries 0.6 gallons more fuel: 4.2 gal/Triumph vs 3.6 gal/Ducati.
When it comes to braking, you’d think the Triumph’s stopping performance to be fine, until you hop on the Icon and experience much better power and modulation from its single 330mm disc and 4-piston caliper, compared to the Trumpet’s single 310mm disc and 2-piston caliper. The Ducati also comes equipped switchable ABS.
Ducati Scrambler
+ Highs
Quality braking performance
Light makes right
A retro-cool Monster
– Sighs
Fueling issues
Ground clearance/engine exposure
Low-grade suspension components
The Triumph regained some points in the suspension department. Both bikes are equipped with mediocre forks and shocks, but “the Ducati’s suspension is vexing,” says Duke. “In most situations, the fork and shock feel compliant and smooth. But sharp-edged bumps are met with harsh resistance, indicating an over-abundance of high-speed compression damping. Repetitive bumps, like a freeway’s expansion joints, are especially brutal.”
The nostalgic dual analog gauges of the Triumph (left) vs. the modern digital gauge of the Ducati. The Duc’s provides slightly more info, but neither has a gear-position indicator. What actually bothered us most is the ridiculous routing of the Icon’s brake and throttle lines.
To help lower suggested retail prices both bikes are constructed in Thailand, but the Ducati’s MSRP is significantly lower than that of the Triumph’s. While the Icon retails for $8,595 ($8,495 if you want it in red), the Triumph Scrambler in this color scheme retails for $900 more, $9,499. The base Triumph Scrambler lists for $9,099, but that’s still $500 more for a slower, older scrambler. The non-Icon Ducati Scramblers (Classic, Urban Enduro and Full Throttle) share $9,999 MSRPs.
Triumph Scrambler
+ Highs
Authentic to Scrambler roots
Under-stressed engine will probably run forever
A modern, easy to ride bike from a simpler time
– Sighs
Comparatively pricey
Relatively heavy and underpowered
Needs updating to stay competitive and match its MSRP
When it came time to score the two Scramblers, Duke and I were in basic agreement, easily handing the win to the Icon despite its poor around-town fueling issues. The Triumph scored higher in the Transmission, Comfort and Suspension categories, but it wasn’t near enough to overcome the Ducati’s performance dominance, especially for a lower MSRP.
“Its knockout punch comes in the form of a cool factor that crosses every genre along with a price that undercuts its competition and performance that’s in a different league,” concludes Duke.
Interestingly, the only place on the scorecard we disagreed was the Cool Factor category in which we judge appearance, desirability, poser value, extra features, etc. Duke thought the Triumph was the cooler bike, where I chose the Icon. I think I know why. Did you read Duke’s single-bike review of the Triumph Scrambler? The guy thinks he’s Steve McQueen.
“Triumph’s Scrambler appeals to me in ways Ducati’s can’t, and its coolness is more authentic,” claims McDuke.
Read More Here: http://www.motorcycle.com/shoot-outs/scrambler-slam-ducati-vs-triumph
I test-rode the Ducati Scrambler. "herky-jerky" is an understatement! It's almost unrideable in city traffic. Also, instruments look plasticy and fake-retro.
Other than that, nice bike. Triumph would do well shedding about 100 pounds off Bonneville platform.
Triumph wins hands down in the looks department. Its not all about power, although I believe were about to get a big upgrade on the 2016 Triumphs. Ive heard 1200 water cooled engine. Hope the keep the weight the same, and it will be a home run.
Seems pointless judging these bikes on performance as neither is anywhere near being the ultimate anything. Judge a Rocket or Daytona or Speed Triple on performance; or judge a Trophy, Explorer or LT on comfort. But bikes like these Scramblers should be rated subjectively and in my opinion the Triumph Scrambler is easily the best fun bike I have ridden for a whole lot of reasons I can't even put my finger on. It just makes me feel good. The Ducati is pretty and might have "scrambler" in its name, but a Scrambler it's not. Sadly (or not), the Street Twin with Scrambler kit won't be a Scrambler either, although it will look a bit like one.
Personally I don't like anything about the Ducati Scrambler. Looked at a local Ducati / boat dealership and they did nothing for me and the bike has to stir a little emotion for me to bite.
Not much a fan of any Ducati frankly.
except possibly the MS.
The Triumph on the other hand has the opposite reaction.
I'd love to own one as a second bike. Power is subjective anyway. It's just a marketing tool for the different mfg to get you in the door.
I would be riding a BMW S1000R if it was all about power. Instead after back to back test rides I went with the Speed Triple.
I got my first Triumph, the 2015 model Bonneville Scrambler. Having ridden mostly Japanese for over 30 years. Well happy, just upgraded the rear shocks and what a difference! Looking forward to doing the forks next weekend.
Yep I love my Triumph, what an acquired taste...
Ditto what Dynod just said ... After owning sport bikes most of my adult life I got a street triple last yr and although it's a brilliant bike I just never loved it.... Two months ago I decided I liked the look and versatility of the scrambler ..so I bought a 2016 in blue ...I'm in love. I don't know what it is I love the fact tha it has plenty torque off-road but only just enough hp on road ...I've never had so much fun going slowly in my life.... It's a real motorcycle
So, this thread is a bit obsolete since it does not feature Triumph's latest offering. But just in case you stumble on to this discussion you should get an up-to-date perspective on the 2020 Triumph 1200 Scrambler from a guy that owns a Ducati Multistrada.
most offroad wannabees are too porky, bigger adventure bikes are included + unless your a gorilla throwing a weighty bike around in adverse conditions is rough to say the least + not to mention ducati cost tom upkeep $$$$
1 - 15 of 15 Posts
