I first posted this on the Scrambler section on the AdvRiders site back in January 09. It pains me that so many people waste huge amounts of money on their forks when you can get a dramatic improvement for under £10.
I had a fiddle with my forks whilst doing lots of other things to my bike. My impressions of the forks was that they were far too stiff. So, I got myself some 7.5W fork oil (Std. is 10W) and put that in the forks to a level of 140mm from the top of the leg with spring removed and leg fully compressed.
Why 140mm? Well, the Thruxton forks are filled to that level, whereas the Scrambler is filled to 123mm. So, if you're going to reduce the damping you also need to reduce the spring rate. The simplest way is to increase the air chamber above the oil.
I've just come back from a 100 mile ride to test it and I'm very pleased with the result. I rode a variety of roads from fast dual carriageway to bumpy back lanes covered in crap. The forks now absorb the bumps instead of crashing into them.
I have to say; I don't know if this would be too soft for dirt roads but if your riding is mainly paved roads and, like me, you think the forks come too hard, then you should give this a try.
7.5W oil to 140mm. You heard it here first.
There are a few people on that forum that have tried it now and like it. And, actually when you think about it, it doesn't cost anything because you have to change the oil every now and then anyway.
