Hi all
Just diagnosed my problem with the center stand rubbing on the chain on my 08 Scrambler. I took it off and re-mounted it and what I discovered is that the placement of the bushings that are used for the mounting are critical. If you don't get them in right, you'll have too much play and the stand will pull up to hit the chain. just FYI
