I have bought a Scottoiler for my Bobber Black and want to check, with those of you who may have fitted one, if I am cutting the correct pipe. I have included photos showing the pipe I think it is, I've marked with a bit of masking tape, RHS of bike for clarity.
Cheers in advance
Chris.
Hi !
I installed a scottoiler on my Bonnie back in 2017 and have been using it since. I have not the memory of cutting any pipe. Instead removing a cap and plugging the Scottoiler vacuum pipe. I guess this answer don't help you much.
Regards.
I wish there was a plug but thanks for the reply, I hate cutting into anything unless I'm 100% certain I'm correct.
Regards
Chris
As an update, and for those who want to fit a Scottoiler I have received the following from them;
Hi Chris
yeah you picked the right pipe. Vacuum pipes run from both throttle bodies to the evap cannister. you can tee into it on either side you just insert the white t-piece and then the scottoiler connection on top of that.
