okay if i block off the sai plates into the head , and seal up the
airbox is it okay to leave the solenoid connected ? i know it will still cycle
but if the plumbing is plugged up i will get rid of the decel stutter ?
I'd have to assume that would work if you don't have the cash or motivation to get a Tuneboy and install a non-SAI tune.
i have the motivation and the cash isnt too bad , but i was under the impression i had to change the o2 sensor and tune it on a dyno ,
can i use a tuneboty without having to get dyno time?
Yep, Devious actually has some pretty good tunes and a lot of information on thespeedtriple.com forums. No need for a dyno unless you want your mapping perfect.
