Does anybody understand how the rev limit parameter in the map files for Sagem ECUs relates to the real world rev limit?
On my project I intend to use an increased rev limit (10,450rpm) but I’m not clear on what to input as the rev limit in the map to achieve this. I’ve gone through the standard maps for various Sagem bikes and there isn’t a clear rule e.g. 300rpm below intended limit.
Any ideas?
You don't say what software you're using but there there are four parameters associated with the rev limiter:
Start to cut fuel ......
Increase fuel cut ......
Kill all fuel at ......
Restart normal fuel ......
If I hook up the computer I'll see if I can take a screen shot for you.
I'm using TuneECU v2.5.8 on Windows. It only offers the one 'Rev. Limit' parameter (see below), what software do you use to access the ones you've listed?
Also, would you be able to supply those four parameters from maps 10150, 10071, 10168 and 10178 please?
