Hey gang! Here's the latest. Last year was having charging issues so I replaced/upgraded the R/R, stator, and battery. Been running great/charging strongly ever since. Try to start it the other day, nothing. No lights, instruments, fuel pump,horn. Kill switch is in run position. Check battery w multimeter, 13v. Fuses in grey box all ok. I tried jumping it from the car, it started right up. brought the revs up a bit, checked voltage, it was charging w increase in rpm. Disconnect from car, dies. Thinking I read the battery voltage wrong, I pull battery & bring home to charge. Hook it up to charger, reads 13.0v, fully charged. I opened up kill switch today, that was clean and dry inside. Any ideas why it would start off the car but the battery is fully charged/good.? thx!
