I have read the posts on this site relating to S3 sounds but I still have questions... Here's the situation: I know the S3 has a noisy engine and components and I am used to the sound. Recently however the bike has become noticeably louder. Specifically, I am talking about the clicking sound that comes from the left side of the bike. Normally it sounds like a little ball bearing rotating in some metal container but for the past few rides it is A LOT louder. In addition, whereas it used to be somewhat rhythmic (in tune with the RPMs) it is now sporadic. This noise is so loud that when I open the bike up on the road (remember this is with a helmet on and with 80mph wind howling by) past 6 or 7k RPMs it sounds as if there is a loose part on the bike somewhere. I know the S3 is noisy but do I have something to worry about? Any ideas about what could be going on?
birdman,
If you can check and make sure you 'don't have any part loose', then you 'do' have something to worry about. I had a noise develop in my 97 T595. Sounded like a high pitched pinging. I thought maybe I was about to lose a valve (broken valve spring or something). Well not 3/4 of a mile later it got louder and it was too late. Had to truck it home 150 miles! Took it to the shop and they tore it completely down and found I had lost several teeth on the gears that connect to the starter sprague (one way clutch/bearing). Said they have seen it happen on other bikes and there was an updated part. All is fine now and I still love the bike. Just don't wait too long on these kind of situations because when one part fails it usually will take out others and you can have a totalled motor. I was lucky. Not trying to scare you, but if no parts are loose, then you 'definitely have a problem'.
From my understanding, the older bikes - mine included - are very noisy. As the metallurgical processes changed and the engine design was modified, they quieted down. The '03 might fit into the "quieter but not quietest" category.
I've got the same symptoms with my 01. I think its a rod bearing on mine but im not sure yet without taking it apart
