Not being a purist, I'd like to run my switch wires through my 1976 Tiger handlebars, anybody try this? Also, will the 7/8" Japanese bars work? I'd imagine it would be a slim chance that the serrations in the bars would line up with the P clamps.
I like the clean look better.
I don`t see how you can use the inside of handlebars to route the cables.
Anyway, there`s 2 half packing spacers between the handlebar and the P clip, with internal serrations. (UK bars)
Maybe your set-up is completely different to mine.
You can route WIRES thru the bars, not CABLES.
(I just did this on a '53 T-Bird chopper)
It is much easier if you drill the holes large enough to allow the wire bundle to slip through easily, and first fish a length of strong hard wire through to pull the electrical wires back with.
Thanks for the input. As a long time backyard mechanic, I've routed wires through Japanese handlebars many times, they used to be designed for this. I was looking to see if there were any issues with the switch housings which would stop me from rerouting.
Thanks to both of you for the responces
In fact, the later models (76 included) will easily comply with in-bar wiring, as the wire bundles exit from cut-aways in the housing. Simply drill the holes at the point inside the housing where they will run the most directly into the hole itself, minimizing bends and chafing..
