1 - 12 of 12 Posts
Just did install of Rox Risers on the 06 Tiger. Pretty simple, stock cables ok.
Note on middle pic had to reroute the brake cable to the outside of wire clamp.
Looks good RT! What are the torque values for the handlebar bolts and the Rox provided bolts? I might have to follow your example.:D
Handlebar bolts 26NM
No setting noted on clamps for Rox. Just brought up tight. Blue loc tight on all.
RT - just got my Rox Risers, thanks for the info and pics. Question, did you have any issues tightening down the rear bolts for the stock clamps on the Rox Risers? I did, but just cut a 6 mm hex wrench down to size.
Of all the threads on risers that I searched and read about, I have never seen anyone discuss this??
Also see that your clutch cable has a couple of holes worn through it too!
No problems installing risers that I recall.
and.......
The obvious question.........how do they work on the road???
Been looking at these but wasn't sure how/if they would work better than other options.
Discussion Starter #8
No shoulder pain so guess they work ok
I notice there are some variations in the kits, one has inserts that can be removed if you later want to add 'fat' bars for example.
which kit is yours and did you order it direct from Rox?i
1 - 12 of 12 Posts
