1 - 9 of 9 Posts
Anyone know what the sweep on these bars is? I've found the other dimensions but just need to know if they're a bit straighter than standard. Thanks.
I don't think they are straighter. Close to the bend on 08/09 OEM Maguras, maybe a hair wider.
I am pretty sure that on the Rizoma site they have the exact measurements somewhere as I remember eyeballing them before.
I have an '07 and an '09 side by side in my garage at the moment, the '07 with Rizoma fatbar...
I can tell you ABSOLUTELY that the Rizoma fatbar is not wider than the magura and they are very different feeling. The magura bar is awesome.
The Rizoma site has width, height and diameter measurements but not sweep. I'm after a bar about the same width as standard but with less sweep.
Are those dimensions for the Rizoma? Or the Magura Triumph fatbars. I thought they were the same bends?
Pretty much the same bend, Magura has maybe 1 degree less sweep.
Also like S3Junkie said, Magura is a tad wider.
1 - 9 of 9 Posts
