I have a 2012 T100 with aftermarket British Customs Turn Signals and Tail Tidy done by the previous owner. Everything has worked flawlessly for years until yesterday after installing a few straps under my seat for pannier mounting points, I noticed on my ride to work that my turn signals weren't working. Got home and sure enough Fuse 7 was blown.
Video showing strange flashing
- Replaced the fuse and tested the turn signals: left side perfectly fine, right side, immediately blows the fuse again.
- Replace the fuse again and test the horn and brake lights: all work, just the right turn signal blows the fuse.
- I realize I had tightened one of the straps down on top of some wires and electrical components that were under the seat, so I have to assume a wire must have gotten pinched in doing so. I searched for anything suspicious but couldn't find any bare wire or obvious shorts.
- I didn't have any more 10A fuses so I threw in a 20 just so I could keep testing (not sure if this is a bad idea)
- Next I suspected the rear Right Turn Signal was damaged as its wires were under the strap, so unplugged it completely and tested again:
- Left Turn signals F+R perfectly fine
- Right immediately makes a strange buzzing sound and after 5 or so seconds stops and the tail and headlight start flashing (front Right Turn Signal is not on at all even though its still connected), no fuse blown
- I try plugging the rear Right Turn Signal back in and test again: it flashes very dimly alternating now with the tail and headlight (still no front right turn signal even though I haven't touched it)
- I try unplugging the left rear turn signal and plug it in for the right, and test the right signal switch and get the exact same result on the left signal: very dim flashing alternating with tail and headlight. This leads me to figure the rear turn signal itself isn't to blame.
- Leaving the rear right signal unplugged I turn on the right signal switch and wiggle wiring and connections to see if there is any effect: no effect, tail and headlight still blinking but for some reason continually speeding up until its very rapid and then stops and starts buzzing.
