So decided I'm going to relocate the ignition off the headlight ears due for many reasons. Was set on the left side Joker relocation bracket, but just noticed that they now make a right side option.
Functionally, I think the right side would be great for turning off the bike, as it would allow me to pull in the clutch with the left hand and then reach down and turn off the bike with the right hand.
However, for starting the bike I usually approach from the left side, kick it into neutral and the start it up. So with the right side bracket I'd have to lean over the bike to insert and turn the key.
The left side bracket solves the starting issue but turning it off is the same problem as the current one on the headlight ears. Have to put the bike in neutral first then reach down and turn it off. Since I always park in gear this is an annoying step.
On other bikes I've always had the ignition on the dash so no difference either way, but on the Bonneville I want to keep the gauges as clean as possible.
Thoughts? Experiences from your own install/other bikes?
