I'm buying a pair of rear shock from ricor off a fellow rat.net member. They are for my wife's Bonnie T100. Shocks were set for a rider 220 lbs. I'm glad to say she's no 220. More like 120. Can they be adjusted??
Whilst the spring preload can certainly be adjusted, if the original buyer asked them to be supplied with a spring rate and damping set up to suit a rider 100lbs heavier than your wife, I would expect the spring needs to be changed for a lower rate and the damping adjusted if that's possible without a return to Ricor. But, as Mike says, the best people to ask are Ricor themselves. I've found them to be helpful in the past.
