Hi,
Waited for someone who knows more than me to post but ...
All ball and roller bearings need some internal clearance. However:-
. if the bearing inner race is an interference-fit on the shaft, that'll expand the inner race a little;
. if the bearing outer race is an interference-fit in the case, that'll contract the outer race a little;
. either or both will reduce the bearing's internal clearance, so you start with a bearing that has additional clearance before it's fitted - C3 - then fitting reduces its internal clearance to 'correct' for normal use.
Otoh:-
. if the bearing inner race is a slip-fit on the shaft, the inner race won't be expanded by fitting;
. if the bearing outer race is a slip-fit in the case (there is some external mechanical retention system), the outer race won't be contracted by fitting;
. if the bearing's internal clearance won't be reduced by fitting, CN has the 'correct' internal clearance to for normal use.
C2 has reduced internal clearance before fitting, 'fraid I don't know what'd
enlarge a bearing to 'correct' internal clearance?
Aiui, Triumph spec'd C3 clearance on twins' main bearings; however, in the case of your bike's engine, that was 55 years ago, the aluminium alloy crankcase castings have both aged and gone through innumerable heat cycles - the bearing housings could be stretched - the crankshaft could be worn.
What you
should do is measure both shafts diameters and cases bearing housings diameters with the appropriate micrometers, correct any ovality by machining then take the measurements to a bearing factor, he'll consult charts and mutter some incantations:-
. if you're lucky, he'll hand you the bearings that'll be expanded by your bike's crankshaft and contracted by its cases to normal internal working clearance;
. otoh, if you're unlucky, he'll tell you the shaft diameters are too small and/or housings are too large, undersize shaft(s) must be enlarged by some process (plating?) to minimum diameter
x, oversize housing(s) must be reduced by some process (plating? sleeving?) to maximum diameter
y then he can hand you the bearings that'll work.
Or you can ignore any of the above that's correct, order E2879 and E1591, hope for the best ... ignorance is bliss?
Hth.
