Just installed my RFID Keyless Ignition system.
The bike can now be operated with either the key (as per normal), or with the RFID tag.
It is connected with an auxiliary relay power harness (with OEM connectors) that goes between the Key-Switch and the main harness connectors.
I like the Watch-Band style tag for its convenience and ease of use - no fishing in pocket for the key-fob style. And it makes for easy access to the Reader Device.
So you can just walk up to the bike and start it without requiring the key to be engaged or removed. And RFID tags are extremely secure - there are literally millions of codes.
Spare tags are cheap & easy to program - so can carry a spare in your wallet, or even tucked away in your riding gear somewhere.
Range is only a few inches unfortunately, so tag needs to be in close proximity to the Reader to activate - too bad it wouldn't read from one in your pocket! Hence the Watch-band style.
I also have a miniature glass ampoule Tag - the type used in 'chipping' animals. Some guys implant them in themselves!
Don't think that will be me however! (maybe in a glove or jacket sleeve however).
Actually the complete key-switch assembly can be removed if desired - although is nice back-up and no big deal to leave in place.
..... Although for ultimate security, if key-switch is removed, there is nothing to stick a screw-driver in!
The only thing you miss by not having the Key of course, is the steering lock.
The Demo Video pretty much explains it - but I have it operating so that the Reader device is 'powered' by the clutch switch on the ground side (has plus side permanently to battery +); and then the ignition circuit is latched by the output of the Kill/Run switch so it only needs the momentary pulse from the Tag to 'Set' it.
And once the latch is dropped by the Kill switch, it stays off until Tag is re-presented to the Reader.
So the bike remains secure when parked - there is no current drain as it requires the clutch lever to be pulled to activate. And even if someone was messing with it, they can fool around with clutch & Kill switch all day & it will never engage. There is no visual indication of the reader being powered even if clutch lever is pulled.
Here it is:
Here it is:
