1 - 8 of 8 Posts
For our trip this summer, I wanted a better way to secure bag(s) to my Thruxton. I found a good deal on an open-box dual comfort seat, which made my Kreiga 20 easier to strap down. But I wanted more room for a second bag, or perhaps a Kriega 30... or my wife.
I've been eyeing the Hepco & Becker rack for months, and finally pulled the trigger last week. More expensive than the Triumph one, but I like the look better, at least from the two pictures I could find. Moto Machines was great; they shipped quickly and the rack was well-packed. I recommend them!
Installation is trivial; you need a 10mm socket and a 1/2-inch socket (a 13mm would probably work). You don't really need the instructions.
Notes
  • On the left, the shock mount and the corner of the rack touch. This was enough to nick the black finish. If you care about this more than I do, you may want to file/grind the rack at these corners.
  • You can really bang your hand while removing the seat with the rack installed. Be gentle.
Some pictures:
The factory seat works fine:
Discussion Starter #2
This rack also works well with the factory Triumph soft bags.
The rail does not interfere:
And the retaining "wing" works well when mounted half-under the rack:
On the front, I used the Torx bolt that came with the soft bags, because it's a little longer.
Looks good my bike is the same as your and I just ordered a rack through my Triumph dealer but the one I am getting is black and has a low grab rail and hope it looks as good as your's do, you be surprised in what you can carry on a rear rack.
Ashley
Ashley
Indeed, I think you were right going for black - it will stand out much less.
I just installed my Ventura black rack on my Thruxton and yesterday a friend who work at my dealer gave me a matching Ventura 41 ltr back pack that mounts on the rack its was replaced under warraty as one top D shackel was missing but its new and makes no differents in mounting it on the rack.
Your picture makes me dizzy... blurry & upside down :wink2:
Fantastic documentation, thank you!
1 - 8 of 8 Posts
