Checklist:
1. Replace front stashions... done
2. Replace front brake hydraulics... done
3. Replace air filter element... done, FINALLY! I figured out why the PO used silicone around the air filter housing. There are gaps everywhere! Not sure why but for now will be using some silicone. Won't be the prettiest but just trying to get it road worth now.
4. Flush all fluids.. done.
5. Replace all rubber grommits and washers. Replace front and rear turn signals, indicator bulbs, hook wiring harness back up and confirm all electrics work... umm... skip
6. New tires... done
7. De-rust... done... well, as much as possible.
8. New battery... done
Only thing left is replace the rear brake hydraulic hoses and MC and then put the rear wheel back on. Hope to finish that next weekend and then it's time to see if she can pur again.
