1 - 15 of 15 Posts
Has anyone changed out their battery on the Rocket III, yet? Bear Man needs to change out his battery. I do not recall anyone discussing battery options.
Thanks for any input. One he was wondering about is an odyssey. I think he has one in his Boss Hoss. Was just wondering if anyone has tried one on their Rocket or perhaps another brand?
[ This message was edited by: RidinSunshine on 2007-01-09 08:37 ]
$81.00 is pretty resonable for a gel battery from the dealer. A regular acid battery of that size from WallyWorld be around $45-50.00. Most important though, is to check the production date of the "new" battery to make sure you/he dosen't get one that's been on the shelf for a year or so.
Bigern
Zorba, You aren't listing a Rocket III as one of your rides. Do you have one with this battery in it?
Thanks Bigern for your suggestions.
On 2007-01-13 10:40, Nightterror wrote:
I just replaced my battery with the Yuasa YTX20HL-BS Battery. The only differences over stock is the 310 cold cranking amps (I think stock is 250) and it felt a little heavier.
Makes it a lot easier to start on the colder mornings.
I just got one of those too.....its charging as I write. Glad to hear it has the extra crank on cold mornings....I have been having to jump mine nearly every morning for the past two months.
· Banned
How long have your batteries been lasting? I have my rocket covered in the garage with a battery tender in place. For those who are replacing the batteries did you use a tender during the off season? Thanks Lee
2 years 2 months so far in a garage and no problems yet. I put the Battery Tender on if I haven't ridden in in a week or more and it charges up in minutes.
Mine made it 18 months. The battery was confirmed totally dead at my neighbors shop. I did NOT have any type of trickle charger on it. (I was warned that the old trickle charger I had would overcharge and damage the newer batteries.) I have since purchased a Deltran Battery Tender and put the the permanent charge cable on the battery so that it isn't a hassle to hook up after each ride.
1 - 15 of 15 Posts
