41 - 55 of 55 Posts
New guy here...
I just picked up a 2010 T-Bird 1600 this past week from a friend of mine...It's got 13K miles on it so I'm trying to decide if I want to attempt the valve clearance check myself or let the local dealer open up the valve cover and do it, at least for the first time. That way, if this cam is knackered, they will be the first to see it.
Does anyone have a rough idea what a dealer charges for the valve clearance check here in the States?
I love the bike so far but it sounds so different from my old 1982 Goldwing Interstate which I have kept running for all these years, doing 95% of the repairs myself. At this point, I'm not sure which noises are normal and those that are not.
I'll keep an eye on this thread.
Hi New Guy. Welcome!
Expect about $800 if you don't need any adjustments; that should include a coolant flush and new plugs. Just getting the cam cover off takes about 3 hours; besides all the wiring to move, the coolant has to be drained and a metal coolant tube that runs from the radiator (front) to the thermostat (back) has to be removed. The actual checking of clearances takes like 15 minutes. If adjustments have to be made, they've got to pull the camshaft for any cams that need new shims so you can add another $200 in that case.
I've got a 2013 and Triumph didn't have enough of a conscience to cover a fix. I don't think you've got anything to gain by letting a dealer discover a broken decompressor. I took a gamble by turning my bike over to my dealer that they'd be able to convince Triumph to cover repairs. They tried and I tried and we both got nowhere. I could have finished the job myself and cost me no more than a gallon of coolant but I gambled and lost. I delivered it with the cam cover already accessible and they charged me $400 to check clearances, button it back up and refill with coolant. I don't think that was out of line.
It's a great bike. Don't let all our grumbling about Triumph put you off. We just like to complain.
Thanks for the info! I will probably do this myself then during some downtime. I have no problems wrenching on just about anything. Over the years, YouTube has become more and more my go to for doing more involved mechanical work.
There is a 5 part tutorial on YouTube on how to check and if need be, shim the clearances. I'm sure I can get shims from my local dealer if necessary.
I love the bike so far. My Goldwing never had the low end torque this bike has, but then again, it's set up for touring, plus it's 37 years old. I bought the 'wing when it was 5 years old and even then, it was a pretty placid ride.
With a little searching, you can find a 2009 Service Manual you can download. It's mostly right and indispensable.
Bought a manual for my '14 LT and was worth it to me. Flipping through a printed manual in hand vs a PC is much better for me....old school perhaps. One toner cartridge and a ream of paper probably came close to the price I bought the thing for.
Just wondering sir if you've had any issues since the dealer buttoned up your bird leaving the broken decomp cam in place. Hopefully not!
When i have my valves adjusted it was $400. Maybe it;s because the guy who did it is triumph's demo fleet mechanic and knows how to do it quicker and easier than most dealers, most of whom likely never did one. But whatever the reason $800 for valve adjustment is crazy. I'd never buy a bike if i knew i'd be paying that kind of $ for valves. Om the other hand, Davetac1 at the 1600 forum sold his with 125,000 miles on it and never did a single valve adjustment.
NHnative
I have had my 2010 for 9 years and it has been a learning experience. Hope you don't mind some advice.
While you have the tank off checking your valves you should get rid of the original Triumph MAP tubes and install equal length single piece tubes.
When you turn the engine over to measure the exhaust clearance you have to move the decompressor flyweights. Don't turn the engine backwards.
Yes the chap you refer to is quite thorough.....I learned a lot from that series. Timely but worth the watch
NHnative
Thanks for the hints. I have watched that 5 part series on YouTube on checking the clearances. It's fairly labor intensive but doesn't look all that difficult. It'll be a good winter project. I also plan on replacing the MAP tubes when the tank is off...
Speaking of the decomp cams, i fear mine may have just broken off. In 75k miles mine has never had a hard time starting aside from one ECU adaption issue years ago. But this morning it wouldn't start till i gave it gas and once under way i heard what sounded like something being bounced around inside. Seemed to go away once i got 2-4 miles out but i'm worried i may have that issue. And at 75k miles my bike isn't even worth the cost of the repair, not a great place to be. Triumph has really dropped the ball on this model with this issue and the knock so many have plus the belt issues that plagued many of us. Makes me afraid to buy any new triumph that hasn't been in production for 5 years or more.
What a bummer. Broken parts bouncing around inside your engine! You can't ride anywhere with confidence those parts aren't going to cause the engine to lock up at the worst possible time and cause even more damage or a wreck.
I feel very fortunate to have a 2010 with 93k miles, no serious issues, 2 cross country trips, never left me stranded, and my valves haven't needed adjustment. I have checked my valves several times and pulling the plugs is not necessary because their is no compression when the engine RPM is less than 600. If you can lift the rear wheel off the ground, their is a relatively easy way to check if your de-compressors are working.
Pull the right side cover and water reservoir so you can access the front belt pulley. With the bike in gear you should be able to use a wrench on one of the pulley bolts and turn the engine over. Make sure you pull it in the forward direction only. I don't remember the torque on those bolts but the engine should turn over before the bolt moves because their is no compression.
Since i posted this it's been starting normally, no noise, and running as good as ever. May just have been a fluke so keeping fingers crossed.
I have 2014 1700 LT. I removed the decompression cams and actuator pins before last summer. It did reduce some of the minor chatter in the top end, especially after the engine was heat-soaked from riding all day. But After 6,000 miles or so I put them back on. The starter struggled to start the engine most times. I got in the habit of getting on the bike and while in gear, bumping it a half turn to get it off TDC then shifting to neutral to start it. (big twins almost always end up on compression stroke when the shut down). I was worried I'd get somewhere, it would not start on the first couple of tries and I'd run the battery down to where it wouldn't fire the FI so I couldn't even bump-start it and I'd be stranded.
But I know what you're saying. Knowing those throw-weights are spinning around at 1000-3000 RPM with just a little E-clip holding them to the cam plate is just a bit unnerving.
FF
I paid 3x that and mine were in spec! this was 2012 and no shops had opened one up yet, but despite the disturbing noises the engine made had I been able to get a 12k service for $400 I would have kept it much longer.
41 - 55 of 55 Posts
