Run 30 to battery plus (via a fuse);
85 & Return from grips to battery -ve
87 is output to Power for Grips
86 is from switch for grips; input for switch from any source that is on with ignition.
You can select any convenient line that is only powered when ignition is on - the power through the switch is minimal as it only powers the relay - so you can use virtually any source without compromising anything. The main power for the grips will come directly from the battery.
Just pick a wire that is convenient to your switch.
If your switch is on the left handlebar, then you can tap into the blue wire in the harness that runs up to the left bar switch (main/low; turn; horn etc) (or pick it off near the connector plug off that same harness)
