1 - 2 of 2 Posts
G
Does anyone know what washers and spacers go where when you are installing the bracketry that holds the headlighs and gauges on an S3/S4? I finally got my replacment parts after my wreck and cant remember for the life of me where to put the 3 parts. The tech manual doesnt do a good job of showing a difference and telling me where the washer goes.
G
Discussion Starter · #2 ·
Ok, I figured it out. I dont know how, but I did. The fat spacer goes on the bottom on the inside of the bracket, with the washer on the outside. The thin lipped spacer goes on the top, on the outside. It is easier to install if you slide the fatties in the bracket, slide the bracket on the mount, then fasten one of the thin ones on the top. Then you can put the washers and bolts in at your lesure.
1 - 2 of 2 Posts
