61 - 78 of 78 Posts
Angels went on today. I got off work early so I got to spend most of an hour and a half finishing off the old tires. The front PR4 had 11,756 miles and still had a little tread in the center, but two bands worn nearly slick at what I'm guessing corresponds to my most used lean angle. The rear PR4GT had 5,020 miles and was down to the wear bars with wear more concentrated in the center which I think is partly from my enthusiastic use of engine braking and partly from waiting too long to get back on the throttle on corner exits.
With the new tires on, I went to Arby's, the bank, and the petrol station, with a couple detours along the way. I only did 16 miles so it's a bit early to tell much except that they feel different turning in at low speeds. I should learn considerably more this weekend.
I am of the opinion that even if you put the exact same tires on as you took off, they are going to feel different. They should...they're new. I know I don't have to tell you to check your pressures for a few days, but I'm going to anyway. Enjoy!
Has anyone tried any budget type tires like the Shinko brand? I've run them on a couple of my other bikes (Shinko Ravens)and have been quite happy with the cost vs. wear and handling.
Read Only
I've always wondered how people get such little mileage out of tires compared to me... The Diablo Rosso Corsas that came on the bike, gave me over 9,000 miles. I have the Rosso IIIs now, and am at 9,500 miles on them. Probably have at least another 2-3,000 miles on them. I ride pretty hard, with lots of engine braking (I typically don't use the brakes unless I need to slow down very quickly, or I'm under 15mph. Everything else is done with engine braking) and I corner decently fast, too. Lots of freeway and backroad miles... I'm wondering if maybe its the asphalt. Are your roads crazy rough? And I don't mean potholes - we have tons fo them here, too - I mean like texture. Is your asphalt like sandpaper?
About the Angel GTs: they have a different profile on them. More shallow than most sport tires. So they'll feel a lot different on turn-in. That's what has me considering PR4s over them on my next tire swap. I love Pirelli tires, but I also want to keep my sporty turn-in. You should keep us posted on how you feel about them in the long run.
Probably tire pressure. I'm the same as you in terms of getting more mileage than others. I am around 150lbs so a little lighter than average I'm guessing but mostly I think it's because I run 32/40 (roughly, depending on ambient temp) and that keeps the profile and a smaller contact patch. I'm only guessing but I bet most other riders here run quite a bit lower pressures.
Anyone ever mixed tires? My pilot road 2 front still has plenty of life but I want to put the pp3 on the rear and try it out
Sent from my SM-N910V using Tapatalk
I bought mine, a 2014 Street Triple R, with 9393 miles on it and a brand new T30 on the rear and what I'm assuming was the original front tire which was down to cords showing, lots of them, on the port side and a real "V" shaped profile from the wear pattern. I like Metzlers so I put a M7 on the front. I've only ridden it about a thousand miles so far and haven't been out in the back country but so far they seem fine together. I'm running 34 front and 36 rear pressures.
+1 to the Angel GTs. Oddly enough I have them of my VFR and my Speed Four. And they've rocked everything I've thrown at them. That includes a NY <--> Asheville run on interstates, Skyline Drive and the Blue Ridge. Coming down from Mt Mitchell in solid clouds the tires held me in full confidence.
Update
I said the low speed turn in felt weird when I first got the Angel GTs. Then I found that the shop had put the factory recommended 36/42 tire pressures in. I aired down to 32/36 and all was well. Over 2,000 miles on the tires now and loving them.
Figured I should also put in an update on the Dunlop Roadsmart 3's. I have over 2,000 miles on them at this point I think. From a feel (on turn in, etc) perspective I don't feel too much of a difference between these and the stock. It feels a little better turning in but since the stock were squaring off when I got the puncture and replaced them I would say it's the same.
I don't notice any real differences in grip either. I'm not riding like a Street Rossi but I am not afraid to lean. I have ridden it a few times in the wet and they do seem to have better wet grip which is to be expected.
All in all I'm super happy with them and I don't think that's confirmation bias. They seem very close to on par in the dry and better in the wet than the pirellis.
I really am hoping for longevity (I'm in a flat, straight road area) and haven't noticed any squaring off but it's still early at this point.
I did an unscheduled run flat test on my front Pirelli today. Riding back from Reno on I-580 (knew I should have taken Virginia St. to the old road through Pleasant Valley), I hit some kind of debris on the road at highway speed. About a mile or two later I noticed the steering effort was much greater than normal. I pulled over and determined that my front tire was completely flat with not one, but two fairly large gashes in it. I didn't want to pay for a tow all the way from Reno, so I decided to see how far I could limp it. Short answer: All the way. After about 30 miles at mostly 30-40 mph (less for turns), and stopping several times to check the tire, it's sitting in the garage with the tire still in one piece. I'll get it replaced later this week.
Wow. That had to be a bit nerve wracking when you pulled over and saw the gashes. No damage to the rim limping it home?
Should have just wheelied it all the way!
12850 Miles on my 09 STR, and I just strapped on a new set of Metzler Roadtec 01. Replaced a well used set of Avon Storm somethings, that were on the bike when I bought it 3500 miles ago that seemed fine after I burned off the tire shine the previous owner put on the contact surface.
250 miles in, the Roadtecs feel pretty great. The front end felt heavier at first, compared to my well worn Avons, but I don't notice it anymore. Tires hold a line fantastically - like I don't really have to maintain my lean with increasing throttle. I can lean, aim and it sticks.
Rim looks fine. I aired it up for the 2.4 mile trip to the shop, and it didn't go all the way flat until the last 3/4 of a mile. The guy said it'll be done Saturday. Another Angel GT is going on.
61 - 78 of 78 Posts
