Hi,
baffling why they just didnt use a standard jam nut. I guess I can snug that up with a screw driver of sorts.
The assemblies AP supplied for the T160 (earlier than the twins) do have a standard hex. nut jam/lock nut. Baffling is why that was changed for something that
couldn't be tightened/loosened with a bog-standard 7/16" AF open-ended spanner/wrench ...
9mm adjustment distance. I followed the instructions closely and I ended up at .34" distance. Another half turn on the cast body probably would have gotten me another .02"
set screw
that seats on the flats milled on the male threads of the cylinder
Mmmm ... for clarity:-
. the linked Lockheed instructions show to set the master cylinder and pushrod in the mounting casting
before setting the clearance of the 'boot nut';
. the master cylinder's external mounting thread is 1 mm. pitch; i.e. a complete turn of the cylinder moves it in/out 1 mm.; therefore, having: removed all "lost movement" between master piston and pushrod, turned the cylinder "one complete turn" (1 mm.), the following "part of a turn" moves the master cylinder into the casting less than another mm.;
then the 'boot nut' clearance is set to the ~3/8" and the nut locked on the pushrod thread;
. however, the given measurement is a ridiculous level of precision;
all that's actually required is: the 'boot nut' isn't so close it hits the mounting casting before the master piston's full travel; the 'boot nut' isn't so far from the mounting casting the boot's pulled off either the casting or the nut's lip.
what the diagram does not show is the way too long set screw and lock nut
Ekshully ... they're peculiar to your master cylinder mounting ...
Original locking Allen grubscrew is 10-24 before 1980, M5 (5 mm.) after. It's about the same length as the mounting casting thread so, when it's screwed down to lock the master cylinder, the top of the grubscrew is below the outside of the casting ... I usually smear a lump of grease in on top of it to keep road crap out and the grubscrew in even if it comes loose.
By eye, the setscrew in your photos. is 1/4"? If so, someone's been there before you, drilled out a corroded? original grubscrew, mullered the original casting thread, drilled 'n' tapped it to the next size up bolt he had lying around? Whether it's 1/4" or original 10-24, just replace with a shorter/standard grubscrew?
Hth.
