The later TBird fender will fit a TBS. You need to keep the front part of the fender. You know the part made of plastic. I believe the Legend rear fender is the same as a TBS, but I can't confirm that.
So Not sure about a 98, if you have the chrome mounting brackets vs. the polished aluminum ones it will bolt on. Also If you have the cast aluminum brackets, I suspect that you could swap the mounting brackets and then the TBS fender would fit.
Does that make sense?
