Hi all i have a question about the rear calliper on a 05 955i. The calliper is firmly attached to a plate, whilst the calliper doesn't move relative to the plate to which it is attached, the plate itself move by a few mm backwards and forwards (front to rear not side to side) if you grasp the calliper and give it a shake.
Not having noticed this before I wondered if this is normal or if I should be heading to the repair shop? Does yours move a little or is it rock solid? I would appreciate any advice. :???:
It will move alittle bit. I dont think you have anything to worry about
Thanks chaps. Checked the recall as well, no-problem can you tell me why it moves?
