Went riding on my '06 Sprint ST yesterday. I applied the rear brakes, brake pedal went down 90 degrees and no rear brakes! Pulled over and the rear brake line where it goes into the banjo bolt on the caliper was leaking, leaking brake fluid all over everything. I obviously need a new brake line, but is it possible there is a problem in the master cylinder also? I may take it apart tomorrow to check it out, but does anyone sell a rear master cylinder rebuild kit?
Unsure why you would blame the master if you say the line is leaking at the caliper
Sent from my SM-G955U using Tapatalk
Yeah--you are both probably right. Just wondered if a problem in the master might have caused the leak in the line. I'll replace the line and go from there. Thanks.
