does anyone know the rear axle nut size for a 2009 triple. search turned up nothing and its not 46mm or 1 3/16 its way bigger than that. i just wasted 75 at harbor freight,nothing they had was that big.thanks in advance for the info.joey
Actually it is 46mm.
You have some weird **** going on with your bike if it isn't.
1 3/16 is about 30mm. It should be 1 13/16 which is about 46mm.
There are heaps of them on ebay ranging from $10 to $50, just search for 46mm socket. You may need a 1/2 to 3/8 adapter, make sure you get the right one if you do (reducing 1/2 drive to 3/8 drive not the other way around).
