1 - 7 of 7 Posts
I'm looking to replace my rear brake pads, and as a result need to remove my rear wheel. I'm having a hard time finding a socket large enough to fit the rear axle nut! My best guess is that it's around a 1 7/8th is this right or is it a metric size? Also where can I get a reasonably priced socket of this size? Any help would be appreciated. :???: :???: :???:
its 46mm. but I have used a 1 7/8 on it. I assume its the same on the 02.
[ This message was edited by: Limey on 2007-03-04 14:30 ]
It's 46mm, and the Standard size is 1 13/16, but the metric size fits best. You can replace your pads without removing the rear wheel. I did it. You just have to be careful not to scratch the wheel.
Axle nut is 46mm, but 1 - 13/16 works out to about 46.05mm.
You can pick up a 1 - 13/16 x 3/4 drive socket at any NAPA store for about $12.
I've seen this same topic about five times in the past three months :-D
And you didn't seize the opportunity to scream out "SEARCH, SEARCH LEARN TO USE THE SEARCH FEATURE" :2guns: You're not in the spirit of the Internet forum!
[ This message was edited by: kcjones on 2007-03-04 15:28 ]
Thanks for the input, and sorry for not doing a search!! I'm surprised I didn't incur evryone's wrath!!! Lesson learned. Also, Bill I got those Vortex sliders on....brilliant! Almost custom made! :-D
1 - 7 of 7 Posts
