1 - 10 of 10 Posts
here is my 09 I have researched alot of console options but due to the cable from console to ecu its hard to find something that will work.
My other option is to find a used flyscreen for an 08-09 that I can work on my dremel work.
What are you trying to accomplish? Did you switch bars/clip-ons and having clearance issues? If so, I'm having the same problem. Just got new SM2 bars and the brake lever hits the flyscreen. Clutch side is fine though. I'm thinking I may switch to have the guages/light move with the forks rather than be stationary.
the console is just pure ugliness. clearance is not much of an issue, i have made adjustments that have the clip on just barely touching the console when turned all the way.
yes i mean the control panel, instruments, etc..
ok I looked at the trailteck but cant find out what there cable connections are. does it use the same cable connections that speedy uses?
It all really depends on what you want it to do and
look like and mostly how much your willing to spend.
This company makes MANY some look like factory
units some look pretty custom.
http://www.kosonorthamerica.com/flashpage_us.php
Moving on up in price you have Mychron which you
will have to mod your harness to make it work. This
you will find is the case with most gauge panels.
http://www.aimsports.com/moto/index.html
Moving up in price you have
http://www.translogicuk.com/lap-timers-md1.htm
http://www.who-sells-it.com/cy/motec-690/motec-parts-catalog-350/page-24.html
What are you trying to make it look like,? what
are you wanting it to display/do? How much are
you wanting to spend? I did a LOT of research
when I was building my motorcycle I may have
just what your looking for saved on my PC.
Discussion Starter #8
yeah kozo has some nice stuff but again you would have to alter the wire harness. the speed triple uses a cat type cable so splicing it is out of the question, I would need to trace it all the way back to the ecu and when successful I would still loose some features.
Some of the other ones you posted are made for the interior of cars and would not be weather proof.
It would require you to fab something but how about taking the guts out of the console and using them in some form that you like. That way you don't loose functions and plug/play qualities. Just a thought.
You'll have big problems trying to integrate any other cluster off the harness to the OEM unit - that uses a CANBUS system so the data is in a digital stream from the ECM (other than the idiot lights) - that covers Speedo, tach, water temp, neutral switch, fuel level; etc
If you want to use a conventional cluster with discreet signal functions, you'll have to pick them up at source and in many cases add additional senders.
1 - 10 of 10 Posts
