Looking for some advice, got some very corroded header studs/nuts. The two in the middle the nut has actually disintegrated and flakes away however the stud still feels solid. I plan on swapping them for some stainless studs and nuts, i'm going to soak in penetrating oil and use a blowtorch before trying to remove and hopefully this won't shear the studs and will loosen. Will also remove radiator before attempting.
Any additional tools i might need? i'm planning on using a socket wrench on the nuts that still have their shape and the bolt remover sockets (with reverse spiral flutes) on the really corroded studs.
