1 - 9 of 9 Posts
I was wondering,
I know the rec/stator issue is common in this model. At what mileage do you think it'll start going bad?
If I get a shop to change it out..for parts + labor..at around what cost will it be on average to get something done like that?
Thanks much
Picking a period when it might go is nigh on impossible. If you're thinking of swapping out as a preventative measure then purchase the parts through links/advice provided here I.e. Ricks Motorsports for stator and roadster cycle.com for the reg/rec. The cost will then be down to the hourly rate your local charges or have a crack yourself with the excellent guide in the sticky RE charging and diagnostics...Dont forget to do the wiring upgrade while you're there to get the full benefits
Sent from my ass using Tapatalk
Maybe never? If it ain't broke, don't fix it!
I didn't have an issue with my 05 until I started preempting problems lol. Then it became an ongoing battle replacing dead stators and different R/R's.
Check your vin number. There was a change to the rotor, stator, cover etc at #356143. I believe the later parts were more reliable?
my VIN number ends in 388184. Its a speed triple 2009.
That's some good/interesting info Ferris. May I ask where you got that? if you still remember that is.
I was wondering,
not easily predicted, but it's best to swap both at once.
Thanks much
Replacing the stator and regulator isn't an insanely difficult DIY job, but to have a shop do it, it'll be their hourly labor rate and probably 3-4 hours of it.
I just replaced stator+regulator on my 2008 (w/ later VIN#) ... here's some infolinks:
debugging / diagnostics
http://www.triumphrat.net/speed-tri...-diagnostics-rectifier-regulator-upgrade.html
helpful install threads
http://www.triumphrat.net/street-triple-forum/624369-new-stator-and-rectifier-r-r-install.html
http://www.thespeedtriple.com/forum/how/26543-stator-fix-final-solution.html
http://www.motohowto.com/content/re...rectifier-regulator-triumph-speed-triple-2006
http://www.freeranging.net/blog/2011/07/20/repairing-the-triple/#more-1532
suggested replacement parts @
http://www.motohowto.com/content/re...rectifier-regulator-triumph-speed-triple-2006 comment from Franck (not verified) on Wed, 05/22/2013 - 22:24
stator
depends on engine # (engine# located on top of crankcase)
RM01390
https://www.rmstator.com/en_ww/prod...-st-1050-tiger-1050-1050-se-2005-2012-rm01390
regulator
get a mosfet with high current
RM30507H
https://www.rmstator.com/en_ww/prod...-749-848-999-1098-1000-1099-1198-cc-1998-2013
1 - 9 of 9 Posts
